Hi, I moved into a place about 9 months ago. From the beginning the toilet has flushed "oddly" with little consistency except that it normally gets the job done. However, after a flush it burps and gurgles pretty vigorously. Over the summer I checked the vent in the room to make sure it wasn't clogged and causing a vaccum...I used a large snake and found nothing therefore making no improvements. Now, the toilet doesn't seem to want to flush at all. I cannot even flush liquids as the bowl fills, quickly as usual, but then drains slowly...so add any non-liquid material and it takes two or three flushes to at least minimize the content in the toilet.
This morning I tried dumping buckets of water down the toilet. I was dumping about 2 gallons at a time in a 1.5 gpf toilet. The water would go in, but not out. The only thing that would get the water to go out was repeated plunging or adding more water to the point of almost overflowing and then it still only slowly went down. I was hoping for maybe an obstruction in the line that I could flush away with water but that seems to have not worked. I dumped about 10 gallons of straight up water down the toilet.
Suggestions? I have a septic system and they are coming to pump it Monday as I'm hoping that might alleviate the problem but the shower that is 3 feet from the toilet drains just fine still?
