black iron union
  • jocar
    • 7
    black iron union
    When reassembling a black iron union on a water heater, do you use any pipe dope or oil on the two mating surfaces of the ground joint union or do you reassemble it dry.
    union
    why would you use a black iron union on a water line in the first place?
    usually its a dielectric union.
    the mating surfaces of a union is machined so it seals dry - no compound on the joint.
    the threads mating the union to the external piping uses a joint compound only.
    • jocar
      • 7
      black iron union
      The union is on the gas line,sorry for not explaining it better.
        union
        still doesn't change anything. no dope on the mating surfaces. one end has a ground bevel the other has a brass seat.
