Soil pipe
  • Xfitter71
    • Feb 2013
    • 37
    Soil pipe
    The home was built in 1909. I thinks bathrooms much later. Very strange plumbing. The cast iron soil pipe goes to city line. I think there is build up in the main trunk. Has a clean out on end and plug has been changed to PVC. It's a straight run out of the wall. What's the best way to clean it out?
    • 8747
    waste line
    is the pvc installed in the cleanout fitting? did they leave another cleanout cap?
    they should have installed a tee wye fitting with a cap.
    if there is nothing like this then you'll have to remove the pvc, clean out the line and re-pipe the pvc.
    other alternative is to clean it out via the roof stack.
    • akaothermick
      Absolutely incompetent
      • Jan 2014
      • 141
      soil pipe
      I have snaked out by removing the toilet and going in through the toilet flange, just a thought.
      Mick
        • 8747
        clean out
        good suggestion but are you going to remove the toilet every time there's a blockage?
        be better to put in a pvc tee-wye with a cleanout fitting in the horizontal run in the basement.
        • Xfitter71
          • Feb 2013
          • 37
          We rented a motorized snake and cleaned it.
