Tried to fix one problem and created another....
Our shower has been squealing after being in use for a good minute or two, and the squealing will go away when the water pressure is lowered, but I was reading about how I could have a bad washer causing the problem and was investigating today in hopes of fixing it. Decided to look at the tub spout as well (this is completely new territory for me) and removed it first by loosening the screw on the underside. Pulled it off to reveal the copper piping that has some buildup around it. Realized after looking at the spout that this is likely not the source of my problem, I put it all back together as is, changed out the shower head (in case its just deposit buildup causing the squeal) and turned on the faucet. When I pulled up the diverter I immediately noticed water dribbling out from the base of the spout where it touches the tub wall.
Removed the spout again, put my finger over the copper pipe to act as a diverter and ran the shower - no leaks - so the pipe is fine. I guess I just somehow broke my spout by removing it??? I dont fully understand the inner workings of it, but does this sound possible?? I used some steel wool and cleaned off the gunk around the pipe but I have not reconnected the old spout since having done so. Next step would be to replace the spout and hope for the fix so I can get back to seeing if my shower is done squealing. Thought I would ask here first before I run out and spend money on it. If I'm going to replace the spout I'm thinking I'll go ahead and update the rest of the faucet as well.
And as a related question - the hole that was cut in the tub around the copper pipe is quite a bit larger than the pipe itself - is that meant to be left open? Seems like if the tub spout failed (as I'm assuming mine has) the water is going to go straight back into the wall and could potentially cause a major problem.
