Water Softener Drain
  • s229
    I'm installing a softener in a basement and need to tie in a drain. Is there anything wrong with tapping into a section of PVC drain and installing a fitting with a small check valve? There are no open drains in this basement. Washer is installed on second floor.
  • Hube
    • Nov 2003
    • 453
    Some local codes will apply to the type of drain material(plastic, copper pvc) used to drain the softener. Also, if you have a Manual, it will state how much the maximum distance in vertical heigth you can discharge. This distance is usually a max of 8 ft. Check your local bldg codes. Do you have a sump hole in this basement?. Sometimes it can be used if approved. Good luck Hube
