My house in ~4 years old, and I believe this problem has always occurred, but we rarely used the guest shower before. Now that our daughter is old enough to use it, we need to get it repaired.
The setup is a shower/tub with a single on/off, cold/hot handle that doesn't pull out. In order to get the shower to go on, you need to pull out a knob on the faucet itself (seems rather standard). It looks almost exactly like this, but I don't know the brand mine is (it was installed by the builder when the house was being built).
The problem is when you turn the handle to get water to flow from the faucet, the shower head drips water constantly. It appears that it drips heavier depending on the location of the handle, leaving me to believe it may be a pressure problem.
Any suggestions???
Any suggestions???
