Good evening,
The problem I am having is this: The toilet in my kid’s bathroom was clogged. I plunged it, and it works just fine. However now it seems the toilet in the master bathroom is clogged/drains very slowly. I plunged it, and snaked it, but this did not fix the problem. I have also changed all of the hardware in the tank; this did not fix the problem either. I thought it might be some type of pressure problem, I guess I thought wrong. When I flush (with the new hardware), the toilet fills very quickly and would over flow if I did not manually close the flapper. The water drains very slowly, down below the normal fill level in the bowl, and bubbles/gurgles. Does anyone have any ideas; do I need to call a plumber
TLL
TLL
