I guess this is a mixing valve, but I can't figure out why it's there. The water in these pipes flows toward the wall in this photo. The pipe on the left is a cold water pipe that goes to the garage only (it has a shutoff valve upstream from the photo). The pipe next to it coming out of the mixing valve is the only hot water pipe to service the whole house. The pipe on the far right is the cold water pipe that services the whole house (except the garage) and it also goes into the top of the mixing valve. The pipe that goes into the bottom of the mixing valve is the hot water pipe coming from the hot water tank. What is going on here?
