We have been having some problems with our well water. Every now and then when you turn the water on it dribbles out. You turn the taps off and back on and you get water. It is almost like there is a air lock. Any suggestions.
Well Water
Emmie. Shut off the pump power, drain the pressure tank of all water. Check air pressure in tank. Air pressure should be 2 psi below cut-in setting of pump.
(if pump cuts in at 30, then air pressure in tank should be 28.)
Turn on power to pump, pump should start and re-fill tank.
Note; Some pressure switches (square D sfg 2 ) have a lever that may have to be "tripped" in order for the switch to re-activate the pump.
If so, hold this lever up for a few seconds when first re-starting.
by eurroexporthello, sorry my english not perfect. my toilet in apartment is making noise ALL THE TIME, like running water sound, even when nobody use it. is this normal...
Channel: Plumbing
