In making a small repair to part of my kitchen sink drain piping, I had to connect a 1-1/2" PVC line to a 1-1/2" copper line. I used a generic-brand coupling from the local big box store that was supposed to be the one for that purpose. That's what the label on it said anyway.
Well, it works, but I'm not sure it's right. Obviously the OD of copper pipe is smaller than PVC, yet the ID of both ends of the coupling are the same. I had to really tighten down the clamp on the copper end so it wouldn't leak.
I noticed on Fernco's website that the coupling they have for this purpose has different IDs on each end as I would expect. Should I go ahead and switch out what I have with a Fernco, or will what I've done be OK? I know the couplings are cheap, but I don't want to do more work if it's unnecessary.
