Howdy , I am in the process of doing some remodeling. I am installing a new shower/tub 1 peice. I have the unit in place and am hooking up faucet. I am redoing the supply lines with cpvc. I plan on running 3/4 inch then reducing to 1/2 for connections .
Now for question #1. Do I need to instal a vent pipe on the shower drain? The only vent is coming off the toilet drain and is steel pipe threw the roof. Now I could run threw the shower walll and tee into the vent pipe in the attic if i need to.
Kitchen sink has the vent under the cabinet. Also what about the vanity vent? Currently I have not installed the vanity or water lines. I have already sheet rocked the walls, but have not painted them. I was waiting to finish the shower job.Will the vanity need vented also and could i use the same type as the kitchen sink under the counter? I am not putting any water lines in the walls except for the shower. I will be going thre the floor in the cabinet. This is a wood floor house on pillars. Space is a bit cramped under house.
If i have been unclear please let me know and i will try to elaberate. Thanks I have been reading all the prior posts trying to get some ideas.
