water line question
  • JCA1
    • Aug 2005
    • 108
    water line question
    When stubbing water lines up for sinks and stuff how far up should I run them? I ran the drain stubs 19" off the floor for the sinks, I was thinking 12" or so for the sinks, maybe 6" for the comodes. Sound right? Also I'm using pex, how will I connect this to the comodes later so the pex dosen't show? Do the make some kind of pipe cover to make things look pretty?
    When running PEX it is necessary to install a PEX copper stub out at each angle stop valve location.
    The Pex copper stub outs have a barb fitting on the input end to permit attaching the PEX by means of a crimp on fitting.
    The angle stub out is then attached to the framing or blocking with a copper pipe clamp.
    The tips of the PEX Copper Stubouts are closed to permit pressure testing the system during the rough in stage. Later during the trim out phase the tips are cut off at the desired lenght and that angle stop or line stop valves are attached.
    • JCA1
      • Aug 2005
      • 108
      OK, is 12" a good height to put the pex/copper stub outs for the sinks, and 6" for the water closets? I was advised by the inspector to use tee's at the stubout location and to install a short section of pipe above the tee to stop water hammer.
        There is no actual code requirement on the height of the supply valves but I think you will find 18" to 24" above the floor to be a more convenient height. This will keep the valves a bit more accessible when things are stored under the sink and it permits the use of shorter supply tubes from the valves to the sink faucetts.
        The drain stub out should be at 18". (The tailpiece from the base of the sink to the input of the trap may not exceed 12" vertical.)
        In regard to water hammer, I would certainly follow your inspectors advice for two very distinctive reasons:
        1. All water supply systems are required to have water hammer arrestors. Formerly we installed whole two whole house water hammer arrestors by intalling a vertical stub about 18" to 20" with a cap on top at a convenient high point in the system. Often the convenient point was directly behind the lavatory supply stub outs. The codes now require additional water hammer arrestors be installed in the near proximity of all fast acting valves such as toilet fill valves, dishwasher supply lines, Ice maker supply lines, washing machine supply lines and any solenoid operated valves such as found on heating systems or lawn irrigation systems.
        2. The second, and in this case, perhaps the most important reason to install the water hammer arrestors as suggested is because making a point to follow an inspectors suggestion goes a long way towards establishing a good working relationship with your inspector. Considering that you are building your own home and doing your own plumbing making a few points with the inspector will go a long way towards having him explain any problems you may encounter rather than write a red tag.
        Quite often when i need to work in a different community and I am not familiar with the inspector I grab a couple cups of coffee and a box of donuts and head for the inspectors office to introduce myself. I then discuss some of the points of code that would allow me options and ask the inspector which option he or she would prefer to see when they come on the job. This establishes from the beginning that I do work to code, but more than that, i respect the authority of the inspector to make the final descision.
        Here is an illustration of a method to make the water hammer arrestors as suggested by your inspector.
