Lots of folks nowadays are installing deeper undermount sink bowls and granite counter tops in their remodeling projects. Then they install a disposal and find that the disposal drain is lower than their wall outlet drain. This allows the disposal to sit in a few inches of water and requires it to "pump" water up instead of relying on gravity.
Taking the proper measurements prior to installation can of course avoid this problem, but my question is what are the options to ensure a proper installation other than lowering the wall outlet drain. And are there any working remedies once an installation like this has been installed. I don't think I've seen any GD that are shorter in height to accomidate a situation like this.
As always, thanks
As always, thanks
