Hot water volume drop?
  • dkpbxman
    • Oct 2005
    • 136
    While I'm waiting to shower and letting the water heat up, I notice that the flow volume drastically decreases when the hot water does kick in. I need to adjust the valves and then everything is fine.
    Is this a sign of HW heater problems?
    Thanks for any help.
    Dan
    Dan
    All the hot water piping, as well as the water heater vessel are simply straight through tubes with nothing that could effect the volume of flow by temperature. Obviously your hot water is flowing ok, otherwise the cool water standing static in the hot water piping would not eventually come through permitting the hot water to arrive.
    The fact that the water volume drops when the hot water arrives is indicative of an anti-scald or thermostatically controlled shower mixer that is not reacting quick enough.
    • dkpbxman
      • Oct 2005
      • 136
      Thanks for putting my mind at ease.
      I was just wondering if this was something to worry about.
      Dan
      Dan
