Break or separation in PVC pipe from house to septic..
Problem is that I can only access pipe on end. The other end is in concrete..Note the left side in the picture is all exposed now after digging..only right side is in concrete.. I can see the separation through viewport/cleanout as it is right in that area.. However, cleanout is right next to septic and cleanout is in concrete enclosure/footing that is right next to the septic..
The break is very close to where the pipe goes into the concrete but plumber says he needs to access both ends to fix it..
Anything out there that will help me fix this with access only on one end.. The relining is very expensive (4Grand) and I don't want to digup concrete and repour as that is very expensive here in Northeast to do (labor costs)..
