My house is 3 years old and was rough plumbed for a bath in the basement. I'm framing it up now and I'm wondering about venting and drain location. As you can see in the photo, where the wall hiding the vent is going to be (the darker pressure treated one), it's only 3.25" to the center of the drain where the tub/shower is going to go.
All the shower bases I've looked at need anywhere from 7" to 16" to where the drain center is (from the wall). Even if I put in a tub with a drain on the side I think the drain in the concrete is too close to the outer wall.
Would you build up a base to put the shower/tub unit on so you can run a pipe to the drain? I was even thinking about bumping out the wall to allow for whatever base I pick, but I don't want that bump in the adjoining room. Or would you bust up the concrete and move the drain to fit what you need? Maybe if I dig deep enough in the dirt where the drain is coming out and chip away a little concrete I could still get the drain connected running downhill?
Seeing the vent coming out of the concrete, I'm assuming that both the toilet and tub drain are already connected to it?
Thanks for any advice! If the wife doesn't see progress when she gets home tonight I'm in deep doo doo! I'm really leaning towards a shower down there. I don't think a tub would hold the heat too well with cold concrete right underneath it.
