Per ASTM (American Society of Testing & Materials) standard the outside diameter of 1-1/4" PVC pipe is 1.660" (1-3/4") and 1-1/2" PVC is 1.900" (slightly under 2")
Before drilling holes for your pipes check your local codes very carefully because the codes are quite specific regarding notching and boring studs, rafters or floor joists. Per pluminb codes, Trusses or manufactured beams may not be notched or bored without the expressed written approval of the truss mfg.
What's the best way to figure out if I should keep running a dehumidifier in my basement versus taking the plunge and having the basement waterproofe...
