Does anyone know how to remove a shower insert without damaging it? I want to take it out of one bathroom and move it to another.
How to remove a shower insert
I removed a shower stall a few years back and it consisted of three plastic panels, a shower pan, four pre-formed corners and a top frame. Stainless steel screw n nuts held the top frame in place as well as the corners. the whole shell fit into a groove on the inside of the shower pan again with screws but these were self tapping screws. the pan's drain screwed into the waste line like a typical sink drain - had to use a spanner wrench to unscrew this fitting - 2 inch pvc. This shower had no trap and fed directly into the waste pipe.Comment
