I cannot get our sump pump drainage pipe connection at the check valve to stop leaking. Its an ABS pipe fitted to a soft rubber check valve secured with a hose clamp. There is enough gravity in the remaining water to leak out around the fitting slowly. Is there a way bond the ABS pipe with the soft rubber check valve material? Thanks
check valve question
