Where do I begin? 75 year old home in Arlington, VA; basement floods and I have some pictures for the best description. On the wall adjacent to the sump pump basin are a few holes where water streams out of every time it rains, the water runs across the floor and into this square hole on the opposite side of the room. (Now I have gone outside and all the drains from the gutters are attached to pvc flex pipe and they are going out towards the edge of the property away from the foundation.)
1. I took pictures of the holes in the wall where the water is coming out of.
2. I took pics of the run from the holes over to the square hole.
3. There are pics of the square hole, which I have no idea why it is there?
Why would someone cut out a square hole in the foundation? Is it possible that is the old sump basin?
Is this repairable? Should I just fill those holes up on walls? How do I fill or how SHOULD I fill that square abyss in the floor?
Help anyone...
Help anyone...
