My new house has a driveway that slopes towards the house (not one of my favorite features). There is a drain at bottom of driveway just outside garage door. The water from driveway pours into this drain and it also has the corregated pipes from french drains coming in on either side. This drain has a basin. When it fills up the water exits a 3 inch pipe that runs under garage floor into another drainage pit inside the garage.
This garage floor drainage pit might hold about 20 gallons of water all the times. When water rises to a certain level it flows out to the main sewage drain to city's system. The entrance to the main sewage system is a 4 inch plsstic pipe with and elbow so the pipe is turned down below the water surface at all times.
The trouble I am having is that the water sitting in garage pit becomes stagnant and starts to smell like sewage. I have confirmed that the sewage pipe entrance is still submerged so the smell is not coming from the sewer. It is the stagnant water.
During winters here in Montreal there will be very little water pouring into this drain (as everything is frozen). This water will just sit for months.
I have only been in house since August and have twice cleared all the water from this pit and re-filled it to get rid of the smell.
I was wondering if there is a chemical I can put in this drain periodically to stop the water from stagnating and avoid this smell.
Thanks.... new house and many many questions
