does anyone know if a rebath tub liner can be repaired?
we had the bathroom remodeled and a worker dropped a tool near the drain
and it put a large dent near the drain. i thought i could either try to put a new drain with a larger covering (if they make such a drain cover)
over the dent. i am afraid water could get under the dent and cause problems. could i use mighty putty to fill in the dent since it is supposely water proof and could stop leaks. this tub liner was brand new and we have never used the tub since the liner was installed.
