My shower stall (no tub, shower head only) has a "Delex" brand single knob control, likely from the 1970's. The shower head drips.
Forgive my lack of proper terminology - I'm no plumber in any way!
A knowledgeable friend removed the handle and "casing" (the "rough"??) and looked at the "valve tree" behind it. There are 3 copper tubes - hot water, cold water, and out to the shower head. He said this whole assembly needs replaced. He said the person who does it will need to be able to sweat the connections.
Another friend agreed and said he thinks I'll have trouble finding the replacement part.
The construction of my shower stall is like this:
- Ceramic tile on plywood
- The plumbing behind that
- An concrete outside wall behind that (it's in a basement)
There's only 1-inch of clearance between the outside wall and the title, and that's where the "valve tree" is. According to this friend, modern versions of this require much more than 1" of clearance. I confirmed that is true at least with some brands during a trip to Lowes today.
Can someone give me proper terminology to use for all these parts and also tell me where I can get the replacement "valve tree" that I need?
If it would be helpful, this evening I can add a picture of the current fixture as it currently is inside the wall.
I'm under a great deal of time pressure to get this fixed and feel hopeless at the moment.
Thanks!!
Thanks!!
