Washer Drain Overflow
  • JDCam
    • Jun 2008
    • 8
    I am having a problem with my washing machine overflowing during the first few moments of the drain cycle.
    Apart from not having a trap (seperate problem) either the vent is inadequite or the pipe diameter is not enough. Due to the cost and difficulty of repairs in this area, I am trying to avoid guesswork. Any comments would be appreciated.
    here is what I have:
    - There is an in-wall plastic drain box that connects to 2" pipe.
    - after about 3" the 2" pipe reduces to 1.5" pipe and travels down approx 30" to a 1.5" Y
    - Upstream from the Y (12 inches) the pipe is capped off
    - Downstream from the Y (30 inches) is another Y creating a 1.5" vertical vent pipe.
    - another foot downstream the pipe enlarges to 2" with an elbow and disapears through the concrete.
    - The main 3" stack is approx 7' from there
    I am considering...
    - Replace the 1.5" verticle pipe from the drain box to the first Y with 2". But from here the horizontal travel would still remain 1.5"
    - or, move the vent to branch directly off the verticle 1.5" pipe
    Any advice would be appreciated.
    thanks
    Cam
  • JDCam
    • Jun 2008
    • 8
    Laundry Drain Overflow
    Here is a crude sketch of what I am talking about
    Thanks,
    Cam
    • jnaas2
      • Feb 2008
      • 213
      The 2" pipe should not be reduced in size all the way to the washer machine box. The 1.5" vent line is fine but there should be a p-trap installed before the line reaches the vent connection to keep sewer gas out of your house
        I am attaching two illustrations.
        The first one is your drawing with the code violations annotated
        The second is an easy solution for you.
