I don't suppose this is really a plumbing question, but I couldn't figure out where else to put it. By the way, I know very little about home repair, so be gentle!
I have now calked my tub three times. The first two times were disasters, and so the third time, I carefully removed the old caulk. I let it air out for a couple of days as I live in a fairly damp climate. I used painter's tape against both the tub and the tile to create a clean line for the caulk. I made certain to fill the tub with water. I let it set for about 60 hours. I used caulk for tubs/bathrooms.
This was just over a week ago. Last night, I noticed the area (probably about 6 inches of the strip) directly under the shower head was no longer sealed. I touched a small area with my finger, and a 3-4 inch section of the caulk just slipped away.
This had happened before (the first two times I caulked the tub) but it was much worse previously. But obviously this shouldn't be happening! Any caulking tips?
The one thing I can think of is that I hand washed a t-shirt last night. I wrung it out pretty well, but I hung it over the showerhead, so it could have dripped. I realize that the caulk should still stay set, but still.
By the way, it appeared to be just fine for the first week.
