I'm trying to dis-assemble a bathroom sink faucet to change the washer. Problem is that I can't figure out how to get the stem separated from the part that contains the seat. I don't know the faucet brand, but it's about 30 yrs old-----maybe Delta.
When I remove the cap, I see the stem exiting from a threaded brass seat, which is directly held onto the sink by a knurled nut (for hand tightening. A decorative cap for the sink top also screws onto this thread on top of the knurled nut.
At the very top of the 'seat' is a section of brass thru which the stem exits, and this section is flattened on both sides, obviously in order to accomodate a wrench. I cant see any seam between the threaded section and the upper section, but I assume there must be one.
Where is it safe to hold the lower section of this fitting so that I may separate the stem from the seat? Do I need one of those under-sink wrenches?
