Hi. Nice forum. This stuff is great.
I'm putting a slab for a shed in my backyard up against the house. There is a gas line underground in that area that comes out of the ground and disappears into the brickwork. This is a slab-on-grade home in Texas.
The gas line is really in horrible condition at and below ground, so I'm going to replace it all the way to the meter. Yes, my shoulders are getting sore.
Before I can put a slab over it, I understand that I need to run the new gas line in a conduit. The ends of the conduit need to be "sealed". How do I seal them?
The conduit will terminate with a vertical section right next to the brick wall of the house. This end will be inside my shed, which will use fences on 3 sides, so it won't be a "tight" structure because of the gaps between each picket. Can I terminate the conduit under ground beyond my new slab for the shed, or do I need to run it until the gas pipe comes up at the meter, another 40 or so feet away? How do I seal these ends?
Any other suggestions are welcome.
Also, I'm not certain, but I think the meter is galvanized, but I've got black pipe in the house. Which should I use and are there any considerations for where I join black pipe to galvanized? (galvanic corrosion in general, I get, but how to prevent it in this case?)
Thanks!
Thanks!
