I'm barely getting enough hot water to last one shower and have to get my hot water heater fixed (again) :-(
My hot water heater (electric "Bradford White", model M250560S5, 50 gallon), is only 4 years old, and I just went through this *&$#ing problem about a year and half ago.
In July of '08 I had a similar issue, and I paid a plumber to diagnose and fix it to the tune of $400!!! The problem was the lower heating element, which was replaced with a different type, one with an extra "curl/fold" in it which was supposed to heat better and last longer. I can't believe this one has given up the ghost now too (or maybe it is the original upper element that is fracked now, or a thermostat, or something).
My original heater (also a Bradford White) lasted 14 years until it acted up. I can't face sinking yet another $400 into this one at only 4 years old. I'd like to try to diagnose (even fix) as much of this myself this time if anyone up here can steer me in the right direction(s), as I need to save the $$$ if I can.
My biggest problem is going to be draining the thing - I have no drain near/beneath the water heater drain valve, instead the water needs to be pumped out to my washer outlet which is about 8 feet away and 6 feet up in the air. I have hoses that will reach that far, and last time this happened I bought a drill attachment that is supposed to work for things like this in the event it happens again, but I just tried a test with that thing and it definitely is NOT going to work, it is crap (or my drill is crap - it can barely turn it, and as near as I can tell from reading the INSTRUCTIONS on the attachment it even says that drills are NOT MADE to operate it for constant periods of time - so they are even admitting that it won't work!!! It took over an hour for the plumber to drain the heater last time btw, using his own "real" pump thing).
So, my questions:
- what steps can I follow first of all to diagnose things to figure out if the problem is one of the heater elements or one of the thermostats? I do have a heavy duty voltmeter.
- if the tank does need draining in order to fix it (like replacing an element) can anyone either recommend an (inexpensive) pump type thing to buy, or are they available to rent?
I'll stop there and see what kind of advice I can get. THANKS...
So, my questions:
