Tuscany Single handle tub n shower
  • Johnz
    • May 2010
    It's an 1.5 in cartridge, self contained with Delta type springs and washers inside and a 3 channel o-ring on the back that mates with same onthe inner body. It still drips continuously. Whats up with that?
  • Redwood
    • Feb 2009
    • 512
    You have replaced the cartridge, springs, and washers?
    Now I can Plumb!
    • Johnz
      • May 2010
      switch
      yes , it's all sealed in a plastic cartridge. 20 bucks for the whole shebang. I'm gettin ready to pop the old one back in, hey they are identical, my luck I put the old one back in the first time. It's possible.
      • Johnz
        • May 2010
        OK identical results,this means..
        2 possibilities. 1 They are both defective. 2 niether one is defective. The springs aren't stout enough on either to hold back water pressure. This thing is made so your average redneck won't attempt to take it apart only buy and replace. It has 2 push clips 180 degrees apart so you can pull off the outter body an get ta the innerds. But, am I gonna break it? Guess I'll try I'm allready out 20 bucks.
        • Johnz
          • May 2010
          Oh yeah,
          Happy Happy Mothers Day.
          I was born on Mothers Day, the 13th. I sure miss mine. Call yours!
