It's an 1.5 in cartridge, self contained with Delta type springs and washers inside and a 3 channel o-ring on the back that mates with same onthe inner body. It still drips continuously. Whats up with that?
Tuscany Single handle tub n shower
You have replaced the cartridge, springs, and washers?I stayed at a Holiday Inn Express last night.
Now I can Plumb!
OK identical results,this means..
2 possibilities. 1 They are both defective. 2 niether one is defective. The springs aren't stout enough on either to hold back water pressure. This thing is made so your average redneck won't attempt to take it apart only buy and replace. It has 2 push clips 180 degrees apart so you can pull off the outter body an get ta the innerds. But, am I gonna break it? Guess I'll try I'm allready out 20 bucks.
