Is there anyone out there that has one of these or has used one? The question I have is how well do they seal? Any issues of leaking with them? Thinking of getting one for our handicapped daughter and if anyone has pros or cons I would love to hear them.
walk in tubs
I've seen a few installed for elderly folks, but the weak point in their design is the seal...which will eventually fail.
Personally, I'd install a curbless (roll-in) shower before installing one of these.... -
Those tubs are fairly expensive too...
Personally if your daughter wants baths instead of showers I'd consider a tub lift...
Bath LiftsI stayed at a Holiday Inn Express last night.
Now I can Plumb!
bath lifts
Hi,
Bath lifts would definitely be the better solution.
Most of the walkin tubs will leak at some point .Comment
The seal is no problem completely, 10 years warranty.
the seal is made of silicone .if the door is glass ,then the seal will be much better.
check the information at triumphwalkinbathtubs.com or search " triumph walk in tubs" by google.Comment
The design in those Triumph Tubs is not the one I'd go with if I was installing one. I'd get one where the door opens inward so the pressure of the water in the tub helps to hold the door closed.
I know that's not quite what the 1 time poster above that was trying to drop a link to a Chinese made tub on an old thread wanted to have right under their post, but it is what it is...
Last edited by Redwood; 11-19-2011, 09:32 AM.I stayed at a Holiday Inn Express last night.
Now I can Plumb!
