Hey everyone. My wife has it in her head that she wants to move our washer and dryer to make a laundry room. Here is the problem. no drain in the room. about 4 feet away through a wall is the main house drain. old soil pipe. thought about breaking it and installing a PVC Tee but that really sucks. Other thought. about 6 feet up is the sink drain from the kitchen that ties in to this main drain. It also includes a cleanout port. My thoughts were to remove the plug in the drain, install a 3-4inch nipple with a T. Cleanout plug on the lower side and a reducing bushing to allow for my washing machine drain on the top. this would put the drain at aobut 6 feet off the floor. washer and dryer would probably be up about 3-4 inches off the floor on a false floor. any problems with this? the kitchen drain runs about 4 feet then 45s into the main drain pipe. i would install a check valve in the top to prevent the kitchen water from running back down.
If this doesn't work or won't work my other thought is to install a sink with a small pump and have everything drain into the sink then up to this pipe. would there be an issue with this? i would prefer the 1st method as i would only need to buy a few pipe fittings and a check valve.
