Brand New Flapper Not Working Properly
  • sarena828
    • Aug 2010
    I just installed a new toilet fill valve and flapper. Now when I try to flush, the flapper drops immediately resulting in the toilet not emptying completely unless I hold down the handle for a couple of seconds. The chain is taut (maybe 1/4" to 1/2" drag) and I can't figure out what else to do to make it flush properly without holding the handle for so long.
    what keeps the flapper open is the air bubble inside it. loosen up the chain so there's some slop in it.
    • sarena828
      • Aug 2010
      Still Not Working
      Thanks for the suggestion. I have adjusted the chain several times, giving it slack and making it taut and everything in between. Regardless, I still have to hold the handle down for a few seconds and wait for the bowl to empty in order to make it work properly. Very frustrating!! The flapper just drops automatically every time.
      • Redwood
        • Feb 2009
        • 512
        A couple of possibilities...
        If you used a flapper similar to the one below are you using both the ears on the hooks and the ring to attach it? If so cut the ring off and trow it away.
        Another possibility is that you are using a 1.6 GPF flapper on a 3.5 GPF toilet in which case you need the correct flapper...
        Now I can Plumb!
        • tpazzi
          • Apr 2015
          I had the same problem as the OP on a Kohler 4634 toilet. Tried installing a new flapper (and ensured I picked the recommended one from Kohler for the model toilet) - didn't work. Tried multiple adjustments to the chain - didn't work. Tried adding a float to the chain -didn't work.
          I finally resolved the problem by stuffing the flapper with a partially inflated air balloon (inflate the balloon enough to ensure it can't slip out of the flapper and clog the drain). The air in the balloon holds the flapper up until enough water has escaped from the tank to ensure a full flush.
          Now I no longer need to hold the handle down. If you are having this problem, give it a try, it works great!
