If the stem isn’t spinning when you turn the tub spout counterclockwise, you might be dealing with a couple of common issues. First, check if there’s a set screw on the spout—it’s often located underneath or on the back and might need to be loosened or removed. If that’s not it, make sure you’re turning the spout in the right direction and that it’s the right type for your setup (some screw on, while others slip on). Also, look for any debris or corrosion that might be causing a blockage. If everything seems right but the stem still won’t turn, there could be an internal issue with the valve, in which case it might need a closer look or a replacement. If you’re stuck, don’t hesitate to reach out to a plumber for help. Good luck with your repair!
I have not done anything with this spout waiting for you to respind. Seriously, I just walked away from this nightmare and there it still is. I will now take a close look! Thanks
I’m new to the forum and have been going through older questions to try and help others who might be facing similar issues. I really appreciate your response after all this time. If you have any more updates or need additional help, feel free to reach out.
What's the best way to figure out if I should keep running a dehumidifier in my basement versus taking the plunge and having the basement waterproofe...
