Im working in a house that was built probably over 100 years ago and these pipes are almost that old. My problem: the retuslrn libe whis is rotted is 3 3/4 pipe. I measured it 3 times. Ots 11.75 cir. I cant undersize but never heard of this size pipe. They make adapters from 1900 to 2022?
Help sizong condesate return line on steam heat
It sounds like you’re dealing with some pretty old plumbing! That 3 3/4-inch pipe with an 11.75-inch circumference is definitely unusual by today’s standards. It’s a good idea to double-check your measurements and see if you can find a conversion chart to match it with a modern size. You might also look for specialty adapters or consult a plumber who specializes in historical homes—they could have the experience and resources to help with these vintage sizes. It might take a bit of creative thinking, but there are definitely ways to work with older systems!
