Toilet runs every 20 minutes or so
  • DKAudio
    • Apr 2006
    • 454
    I have a newer Kohler toiler with a Fluidmaster flusher. The toilet runs every 15 minutes or so because the level in the tank drops. I have tried cleaning the flapper and seat with a non-scratch scotch bright pad (common plumbing trick) to no avail. I also tried raising the foam float higher on the chain so it wasen't pulling up on the flapper so much and that didn't work and also resulted in a weaker flush due to the flapper closing right away. Any other ideas? Can I coat Vaseline on the flapper to help seal it or is that not a good idea? The toilet is probably only a year and half old and was not cheap.
  • Redwood
    • Feb 2009
    • 512
    Replace the flapper...
    I would suggest using a Korky # 16BP replacement flapper.
    Do you use in tank bowl cleaners?
    Now I can Plumb!
    • DKAudio
      • Apr 2006
      • 454
      Bowl cleaners but never anything in the tank, I know those eat away at the rubber.
      • Speedbump
        • Aug 2010
        • 293
        Or maybe it's rust from that old well of yours. The same rust that kept plugging up your constant pressure valve.
        • DKAudio
          • Apr 2006
          • 454
          My well is only for watering my lawn, supplies just 1 outdoor spigot. The house is on municipal and probably some of the best water in MSP.
          • scottz
            • Jan 2011
            • 22
            I would replace the flapper valve. It is probably leaking even if it looks ok. I have to replace mine frequently; they are inexpensive.
