I have a newer Kohler toiler with a Fluidmaster flusher. The toilet runs every 15 minutes or so because the level in the tank drops. I have tried cleaning the flapper and seat with a non-scratch scotch bright pad (common plumbing trick) to no avail. I also tried raising the foam float higher on the chain so it wasen't pulling up on the flapper so much and that didn't work and also resulted in a weaker flush due to the flapper closing right away. Any other ideas? Can I coat Vaseline on the flapper to help seal it or is that not a good idea? The toilet is probably only a year and half old and was not cheap.
Toilet runs every 20 minutes or so
Replace the flapper...
I would suggest using a Korky # 16BP replacement flapper.
Do you use in tank bowl cleaners?I stayed at a Holiday Inn Express last night.
Now I can Plumb!
Did you know some Redwood Pipe is still in service today. -
Channel: Plumbing
