glued wall panels
  • popi
    • Mar 2014
    • 10
    glued wall panels
    Hello everyone I've got a major problem I glued a piece of panel on wall using liquid nail I need to now remove it with out damage it
    is there a blade or solvent that ill neutralize the adhesive thanks in advance
    Sorry Popi, but your in for a world of hurt getting it off without damaging the wall, at best your going to pull the paper from the drywall.
    Using a solvent of any kind is another dangerous task as it will damage the wall all by itself and won't make much of a difference to the liquid nails.
    The best advice I can give is to use a flat spatula and try to wiggle it between the liquid nails and wall, this may help limit the drywall damage.
    • popi
      • Mar 2014
      • 10
      glued wall panels
      Thanks pushkins for the information l also heard you could use an heat gun and that would make the adhesive soft
      • Mark Toughill
        • May 2014
        Glued Wall Panels
        There is another way, the funny thing is, I had a similar problem the other day, where I bonded a metal sheet to a wall using no nails adhesive and quickly found out it was put in the wrong place. Tried everything and you know what, the way I got it off was with a length of cheese wire and me and my friend pulled it back and fourth behind the sheet and it sliced through the adhesive. Was totally amazed how well this worked.
