I need to know what kind of paint I should use on my basement walls. They have been painted with an oil based waterproofing paint many years ago. The walls are dry and the basement has a dehumidifer running all summer. I am remodeling part of the area and want to change the color with a new paint job. Any advice as to what kind of paint I should be using? I'd prefer a satin or semi-gloss finish.
basement wall paint
I believe you want the product called DriLok, available at Menards and other home stores. It is especially made for masonary surfaces. Just follow the surface prep directions given with the product.
http://drywallinfo.com -
If you are content with the waterproofing side of things you can probably paint right over the old stuff. You might want to clean the old paint pretty vigorously and give it a coat of super primer though. Look for a primer that covers everything (oil acrilic etc..) The primer should allow you to switch away from oils if you want to.
LS
If you aren't good to yourself, who will be?Comment
by eurroexportI want to hang shelf on wall but wall sounds hollow when I knock on it, not like the brick walls back home. how I hang something heavy on wall like this...
Channel: Walls and Wall Coverings
