we are renovating our kitchen ,with the new countertop coming we need to get rid of the old cauking that was on the old counter.its hard and sticky.any ideas ?thanks
removing old cauking
Using a razor blade to scrape it off is one of the best ways,you can also try sanding it off, the paper may gum up some yes. If you end up gouging out the area when removing the caulk you can always go back and apply some patching compound, let it dry and sand it smooth.
thanks the razor worked and so did the sandpaper.now thats solved what is your ideas for filling holes from door handles in the middle of a cupboard door ,i am refinishing them with urethane,and moving the handles to where they will actually get used.what do i do about the holes and the staining on the wood?Comment
