Dried paint splatters on countertop
NON-ACETONE fingernail polish remover - that is a good trick... used it a lot before
I don't know about the stainless steel, but I have found that NON-ACETONE fingernail polish remover removes alot of different things, and it is not so harsh. But it has to be the non-acetone. Use a q-tip and try a small area in a place that is not so noticeable.
I have alwasy used turpentine for this before. I guess a credit card would be a safer bet though.
Check out little giant ladders systems, reviews and more.
Thanks, I have an old one that I just cut up. I tried it on a small spot and it worked! It's going to take a while but I have definitely learned to wipe up when it is wet!!
Thanks again so much.
Laura
Use an old charge card (or one that's already maxed out!) as a scraper. It won't mar the surface.If it's Formica or such, then Goof Off might work, too, but I try to keep chemicals away from the counters.
I purchased a home in September and decided to repaint the kitchen. I primed it first (actually that is all I have done) and there are a few (quite a few) places where I splattered and didn't wipe up immediately.
Is there any way to get dried primer off counter tops and stainless steel?
LauraTags: None
