How to remove Joint Compound ...
  • rcrawf
    • Oct 2003
    My daughter's cement block basement has joint compound on part of the wall's, as a textured effect. Sections have come loose and fallen. What is the easiest way to remove the rest? Sand it off? I need to remove it (and the paint underneath) to coat the block with Thoroseal.
    Thanks.
  • Troy
    Moderator
    • Jul 2002
    • 576
    Can you scrape it off? Sounds like it didn't stick too well to that cement block anyway...
    Welcome to the forum!
    Try
    • rcrawf
      • Oct 2003
      Thanks for the welcome.
      I ended up using a spray bottle with water in it to spray sections and let it soak in some, then was able to scrape it off OK. A little bit messy, but not too bad. Now I'm wire brushing the block to remove the rest of the residue and the effloresence so that I can put the Thoroseal on.Any other suggestions would be appreciated.
      Rex
      Rex S Crawford
