I have two buckets of old (3-4 months) All Purpose Joint Compund that has dried up a little. It'd say that it's lost half of it's moisture. It has turned into a bad type of clay that crumbles when you pick it up. There's still moisture, so it's not totally ruined. I'm wondering if there's a way to bring it back to it's full potential. How much water should I add, etc. I have two buckets with around 2.5 gallons apiece.
Old Joint Compund Question
by AshRaeI have a hole in my wall about the size of a doorknob (oops) — is there an easy way to fix this myself or do I need to hire someone? First time dealing...
Channel: Walls and Wall Coverings
by eurroexportI want to hang shelf on wall but wall sounds hollow when I knock on it, not like the brick walls back home. how I hang something heavy on wall like this...
08-21-2026, 03:47 PM -
by BodreyI'm renovating my house right now including installing new drywall. Just today, I started taping the living room, but now I'm seeing that some of the...
