Chair Rail to Baseboard Trim Transition
I've come across this problem many times before, what i usually do is on the corner of the chair rail side I use a bigger piece of material with a routed top (for decoration) that way both the base trim and the chair rail can use the piece as a "stop". It's kinda like the reverse of corner crown molding finishing stops. For that matter you could buy at Lowe's the outside corner crown molding pre made corners, turn it upside down and put it on the bottom corner and have both the chair rail and the base trim run squarely into it.
Thanks for the tip. I ended up getting an outside corner block made for baseboards. It is probably a 1X1 with a decorative routed top and a 90° cut to insert it into an outside corner. It will be perfect to have the two pieces run squarely into it.
ThanksComment
