Hello all; What is the minimum thickness drywall I should use on a ceiling? Is there a good tool that is useful for a one man operation getting it up there. I am aware of those jack things, but that's a bit pricey for something I will use once and never again. I saw a few howtos around where they were using something like a "T" support, and also saw this thing I guess you attach to the ceiling to hold one end up, but I got to thinking how do you take it back out once you are done?
Also once I get it up there, is there a sanding tool that will make that part of it easier? I have a lot of back problems, so looking up for an extended amount of time would be a real pain..literally I need to do this myself, because of limited income. I did call a few drywallers. Told them I had the drywall, screws, tape, compound, and the ceiling stripped to the beams. The ceilings are low, I am only 5'8" and can still reach up and touch the beams from the floor. Everything but holding their hand. But they still wanted ridiculous fees.
