Fix crack in textured plaster ceiling?
  • goshenHeat
    • Feb 2009
    • 25
    I live in a condo, top floor of 3 story building, in SW VA. We have a crack in our textured plaster ceiling - see photo - where there has been contraction / expansion this winter. Click image for larger version
ID:	96617 What is the best way to cover this crack?
  • TinyTool
    • 357
    To address the crack in your textured plaster ceiling, start by cleaning the area and removing any loose debris. Fill the crack with a high-quality joint compound or plaster repair product, smoothing it out with a putty knife. For larger cracks, use a plaster patching compound. Once the repair is dry, replicate the original texture using a texture spray or sponge, then prime and paint to blend with the rest of the ceiling. Keep an eye on the repair to ensure it holds; if the crack reappears or worsens, it may be worth consulting a professional to check for underlying issues. This should help restore your ceiling’s appearance and stability.
