We have an 18' peaked family room ceiling and the drywall tape is separating from the side wall where it meets the ceiling. This was repaired once before for the same problem. The pro that checked this out said that the heat and/or lack of humidity caused this problem. The proposed solution is to install crown molding to cover the drywall tape. Is this a good solution or is there a better approach?
