First of all...
1. Deck MUST be cleaned the right way
2. Never paint the deck ...unless wood is in a very bad shape
3. Darker color = BETTER UV PROTECTION and color will last longer
4. Oil based stains are penetrating products - it means no peeling off , cracking like regular paint or solid color stain
5. Even the best stain will fail if wood is not prepared the right way
6. Even on best prepared deck with best stain - results will vary a lot depending on how much sun , shade , moisture and trees are over the deck.
NEVER NEVER NEVER USE HOT WATER OR BLEACH TO CLEAN YOUR DECK.
If you are here asking about DIY - that's good - you are learning
but it also telling me you probably shouldn't do it by yourself.
Because all of that and more other things - I hate to see when Painting contractors are cleaning and staing decks . It's almost always disaster.
By the way ...with all respect guys....Olympic products are good but not a ideal products. There is many other and much better . Also you will find that many deck / power washing contractors are using contractor grade products usually impossible to buy in regular stores.
Go figure ...now you have to choose the right guy for the job
and that's the hardest part of the whole project.
but it also telling me you probably shouldn't do it by yourself.Because all of that and more other things - I hate to see when Painting contractors are cleaning and staing decks . It's almost always disaster.
