Long time reader, first time poster...
I have a very low pitched roof that butts up on two sides to well pitched sections. I have a rubber roof on the low pitched area now, and it's survived leak free so far. Problem was the previous roof leaked and had no ventillation. Obiouvsly then it'd drip whenever it warmed.
I can add vents to the soffet (will have to drill out some holes to get air into the roof cavity), but where the near-flat reaches the pitched, I can't seem to get enough of a cavity for air to flow to the main attic area.
Can vents be placed safely onto the "higher" part of the low pitched roof? Any venting would be seam taped down, and I assume it'd take a lot of weird water movement to get up and back down inside of a typical square vent?
Is this common or a complete no-no?
We do get all 4 seasons and while rare, 12"+ snow storms show up every 3 or 4 years.
Thank you all for your response!
