I want to pour a concrete slab that on two sides will butt up against an exisitng concrete slab / house concrete block skirting. Is expansion material installed on these edges before pouring the concrete or should I just frame the entire slab, pour concrete, remove frame and then fill gap with something?
Concrete Slab / Expansion?
Like Hayzee says, you need to add your expansion material BEFORE the pour, that way the concrete will push up against the expansion material (felt or foam) and make a nice clean finished edge. To try to add it later will lead to all sorts of problems.
by kemiyHello all. I'm in the midst of planning a much-needed makeover for my home's interior, and I could really use some expert advice and creative ideas. My...
